Old 08-28-2009, 04:31 AM
91Caprice9c1 91Caprice9c1 is offline
Fuel Pressure Gauge for TBI
Since I just told a bunch of people to check fuel pressure on their metros, and it took me a little while to fashion a tool to do so myself back in the day, I decided to post a picture of the apparatus I used when I worked on metros.
This is just your run of the mill Actron unit (that I acquired from Sears) modified with a T-fitting and a couple hose clamps to work in-line with our TBI systems.
-Matt
1996 Caprice 9c1 - Daily Driven Project Car
1993 Geo Metro - Accident
1991 Caprice 9c1 - Destroyed
Old 08-30-2009, 09:32 AM
GM Line Rat GM Line Rat is offline
Re: Fuel Pressure Gauge for TBI
Hey Matt! Looks like this gauge setup required you to remove/cutoff the schrader valve connector on the end of the hose, then modify the setup with the T-Fitting, hoses and clamps..........Correct? A simple but effective setup for checking FP for the Metro Matt......Nice!
Stock Actron Fuel Pressure Gauge
Old 08-30-2009, 11:30 AM
Hugemoth Hugemoth is offline
I bought one from Harbor Freight for under $10 a few months ago when I was having problems with the injector.
Q
Old 09-01-2009, 03:03 AM
Hey Line Rat! How ya been, sir?
You are precisely right.
Beware - the inside diameter of the hose is very small, and requires a little material to be removed before you can get it around the nipple on the t-fitting.
-Matt
