Old 08-28-2009, 02:18 AM
SaintD SaintD is offline
02 F150, wheel clicking
when moving slowly "1-15 mph" there is an odd clicking coming from the drivers side front wheel. I looked for anything that could be loose or a rock stuck in the custom rims. I found nothing.
Ty for any help
Old 08-28-2009, 04:21 AM
Davescort97 Davescort97 is offline
Escort guy
Re: 02 F150, wheel clicking
2 WD or 4 WD?
Old 08-28-2009, 11:33 AM
truckster112 truckster112 is offline
does it stop when you apply brake. if so could be alittle play between brake pad and brake pad bracket, my truck does same no worries. could be that brake pad wear clip is missing, not sure if thats std. ...could be other things too
Old 08-31-2009, 09:34 PM
Originally Posted by Davescort97 View Post
2 WD or 4 WD?
2WD, and no change when the brake is pressed.
Old 09-04-2009, 01:38 PM
okay it seems a bit worse now, can't figure it out. went to a few shops and they didn't know. Ford does not know they said i would have to bring it in for an $85 inspection.
Only thing i can still think of is a wheel bearing.
Old 09-08-2009, 12:29 AM
could be....try jacking wheel off ground and spinning tire and give a listen? may just sound likes coming from front.
does brake squeel when you make a turn?.... thats sign of loose bearing
