Old 08-27-2009, 07:59 PM
racer93's Avatar
racer93 racer93 is offline
Making bolt heads from styrene hex rods
I know this sounds like a stupid question, but here goes, anyway:
What I'm looking to do is to make my own bolt heads with 1mm styrene hex rod and I need for it to be level to look accurate, obviously. Has anyone done this before? If so, what's the easiest way of cutting sytrene rod so that it's level? Maybe a mitre box with a hobby saw?
Thoughts?
Thanks!
Daniel
Old 08-27-2009, 08:23 PM
tuned.by.twenty's Avatar
tuned.by.twenty tuned.by.twenty is offline
AF Vendor-TBT's Owner
Re: Making bolt heads from styrene hex rods
A mitre box and hobby saw is my method and it works just fine.
CrateCruncher's Avatar
CrateCruncher CrateCruncher is offline
Whenever I cut wire, tube or rod I usually take the following approach whether hex or not. I file or sand the end before the cut to as close to even as possible (this is the end that will show). Then I mark the length all the way around the rod. Then I press my #11 on the mark while rolling the rod on a firm surface until it slices through. They call it roll cutting and its a great technique to learn. Eventually you'll get good enough you don't have to mark the rod all the way around.
Old 08-27-2009, 08:36 PM
hirofkd's Avatar
hirofkd hirofkd is offline
I just use a hobby knife, and cut out a whole bunch, like twice or three times more than I need. Then, pick out the good-looking ones with a similar height.
Hiroaki Fukuda
Old 08-27-2009, 11:02 PM
360spider's Avatar
Yep, that is what I do too!
ItalianHorses.net
Old 08-28-2009, 01:49 PM
flyonthewall's Avatar
Car Mod guy
One method I use for cutting styrene strip, rod or tube etc is this...
Drill a hole, at 90 degrees, the same diameter as the rod you are cutting, through a solid block of some sort, you can use a thin offcut of wood for this but I prefer to make a block of styrene made up of 3 or 4 offcuts of styrene sheet laminated together. You then poke the rod through the hole leaving the end to protrude to the same length you wish to cut, then slice off the end with a blade (single edge razors work best) running across the surface of the block as a sort of guilotine.
Old 08-28-2009, 02:42 PM
drunken monkey's Avatar
Razor Sharp Twit
what the guy above said:
making a cutting jig of sorts is the only real way to get almost identical pieces.
Also, you'll tend to get better results using a (photo etch) saw instead of a knife due to the way they "cut".
AF's Guidelines
Read them.
