02 Ram Quad Cab 4x4 vibration at 70mph+
I've got a 02 Dodge Ram that has a vibration at highway speeds of 70 mph plus. I thought might be tires and have now replaced and balance/aligned and still have the same problem. No vibration at any time until 70 +. Any help on this would be greatly appriciated.
Re: 02 Ram Quad Cab 4x4 vibration at 70mph+
driveshaft, front axle shaft, hub??
Bad u-joints.
i have the same problem, did you figure it out?
Mine was a bad u-joint on the '92 Ram. Had to remove the driveshaft to see the loss of full motion on the front u-joint.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" ![]() "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 ![]() Time to turn so's you don't burn.
