Old 08-26-2009, 10:53 PM
alconk alconk is offline
Blower fan not working at all?
Hello again, just thought I could get some idea why my blower fan don't work.. at all. It's in a 92 SE with the 3.3. Is there a way to tell if it's the switch or could it be something else??
Old 09-06-2009, 11:54 AM
Re: Blower fan not working at all?
I'm really surprized no one responded to this?? Is it because nobody knows. I'd really like to fix this problem. Please help.
Old 09-07-2009, 02:25 AM
3100 3100 is offline
Banned
check HTR AC fuse (25A)
then find relay with (Dark Blue, Purple, Black and Orange wires) disconnected relay then jump 12V to purple terminal of the relay connector see if the blower works now. If yes motor is OK, if not motor is bad.
then
- ignition key ON
-select mode (heater)
-blower switch to (low)
-disconnect blower fan relay
- are you getting any voltage on the dark blue terminal of the relay connector?
Old 09-07-2009, 02:58 AM
doctorhrdware doctorhrdware is offline
If no power at all I would bet that there is 12Vdc is missing from the Orange wire which is B+. I would measure the voltage on the orange wire. If it is missing check fuses.
Old 09-07-2009, 03:28 AM
Banned
orange is powered only when there the switch is set to high
dark blue will show some voltage in all other speed settings.
If you are really good with this and want to play with this step by step then do this.
there is brown wire connecting behind the hvac control assembly Cavity C should have battery voltage with key in run position. if not then you have bad fuse or open in between fuse and cavity c. If you get battery voltage at cavity c, you should also get battery voltage at cavity E, durring foloving mode selections (MAX, NORM, B1, Vent, Heater, Blend and Def)
Old 10-02-2009, 05:35 PM
inkslinger00743 inkslinger00743 is offline
the Realy, or the control cluster is bad. Ive seen lots of the 90's grand ams do this.
Old 10-02-2009, 11:24 PM
I feel embarrassed to say what the problem was......no fuse in the fuse panel. Installed one and works great!
Old 10-03-2009, 05:21 AM
Banned
read my post #3 I suggested long time ago to check fuse first
Old 10-03-2009, 11:26 AM
Ya I know. I actually did check the fuses all at once with a test light. This time I went back to check what circut it was in and wow it's missing. I appreciated you help. Thank you!!
