Old 08-26-2009, 06:29 AM
birar birar is offline
trans issue at wot
hey guys i have a 98 gtp with the 3800sc it has 107k its been modified a decent amount over stock running more boost a cam headers and a very small stall converter. i recently just put a new trans in from a 98 regal gs wit supposedly 60k , i checked the vin codes and they were a perfect match rite gears and such. it worked great for a few days but now if u pin it off the line or 10mph from 1st 2 second gear it hits rev box before it shifts, it doesnt seem to slip cuz it pulls hard! just shifts way to high! and it doesnt do it at all at half to 3/4 throttle wrks perfect, i also have a shift kit in it if that makes a difference and my line pressure is higher from zzps pcm please help if anybody no's i really dont want to pull my trans again.
Old 08-26-2009, 09:18 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: trans issue at wot
Do you have any kind of tuner? Is the PCM stock shift points modified?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 08-26-2009, 10:56 PM
my shift points and the line pressure were modified from my zzp pcm, a buddy of mine who did my cam tune was gonna lower the shift points at wot so im hopen that fixes the problem.
Old 08-27-2009, 06:27 AM
BNaylor's Avatar
BNaylor BNaylor is offline
What is the current WOT shift point? Or what are your RPMs reading when the issue occurs?
Typically Stage 1 v1.0 PCMs whether ZZP, DHP or Intense are set for around 6000 rpm and obviously programmed for higher line pressure. Any lower and you will be reverting back to the stock settings. The shift kit should have nothing to do with your issue. All it does is firm up shifts (shift timing) and nothing to do with the shift points.
Timeslip 08/12/06
AF Community Guidelines
Old 08-27-2009, 11:55 AM
its shifting at like 6600 or so maybe higher i dont knw its in that range tho def over 6k it drives fine otherwise shifts great as long as ur not wot, 7/8 throttle is even fine, and like i said its not slipen so thats why i wanted to lower my shift points. the other trans always shifted high so maybe zzp put it that high instead of 6000 cuz like i said the other one always shifted high just not high enough to hit rev box but every trans is different
Old 08-27-2009, 04:50 PM
i did it again today and idk maybe 6400rpm it did it
Old 08-27-2009, 05:09 PM
tblake's Avatar
In God We Trust
I would swap the speed sensor from the old trans to the new one Just to make sure it ins't causing an issue.
Then maybe get it scanned with a trans scanner and let us know if it comes back with any codes.
Old 08-27-2009, 07:30 PM
BNaylor's Avatar
6600 rpms? That is insane. What brand cam do you have, rocker ratio, and spring rates? When you replace transaxles or do major transaxle work you need to get the PCM reset and the adaptive shift data (TAPS) cleared out and relearned. A GM Tech II scan tool is required or maybe a trans shop has a scanner/scan tool capable of doing that.
Timeslip 08/12/06
Old 08-27-2009, 07:45 PM
i ahave a xp comp cam with 105# springs and dif retainers and it has the stock ratio 1.6 rockers ,and the guy who tunes my car has a hp tuner on his laptop who can mess with the trans shift points in such u think that would be capleable? and i just drove the car its siten at about 63 or 6400 rpm i over exaggerated alil ,srry but its still high
Old 08-27-2009, 07:47 PM
i switched the speed sensor and no difference):
Old 08-28-2009, 10:08 AM
tblake's Avatar
In God We Trust
I dont know. Did you make sure the PRNDL switch was adjusted when you put the new trans in? Just curious.
Old 08-29-2009, 12:53 AM
i didnt adjust it at all but all the gears work when there suppose to and thats just a switch for starting and reverse lites, dont think that would cause a problem, thanx for the input tho ik u guys r just graspen at straws and i appreciate it let me no if u guys can think of anything else
Old 08-29-2009, 07:03 AM
BNaylor's Avatar
I suggested the following earlier and there was no reply.
Timeslip 08/12/06
Old 08-29-2009, 09:14 AM
whoops i dnt now anybody with one of those my guy with the hp tuner programer should be able to reset it for me u think thats it? ive never hurd of that before
Old 08-31-2009, 09:08 PM
well changed the shift points on the trans to lower and seems to wrk great they were kinda high they were at 6200 thanx for all the feedback guys
