Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 08-25-2009, 04:05 PM
Cannon2216 Cannon2216 is offline
GM Remotes 98 oldsmobile Remote
How do I program my keyless remote to an 98 oldsmobile 88
Old 08-31-2009, 07:06 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: GM Remotes 98 oldsmobile Remote
1) Turn ignition switch off
2) Install a fused jumper wire (most people simply use a bent paperclip) between pin 8 (black/ white wire) and pin 4 (black wire) at the data link connector (DLC) the DLC is located under the drivers side of the dash, generally bolted to the right of the steering column
3) Close all doors
4) Turn the ignition switch on
5)Press and hold the LOCK and UNLOCK buttons on one remote (both buttons at the same time) for 30 seconds. The doors will lock then unlock
6)Repeat step (5) for each additional transmitter
7) Remove Jumper wire
8) Turn off ignition.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
