1994 Sub "Service Engine Soon" light
1994 Suburban "Service Engine Soon" light has come on intermittently lately, then goes off by itself. I may be wrong, but it is my understanding that these pre-OBDII vehicles need to have that light on to read the error code? I changed the air filter, wires are two years old, I think spark plugs are overdue for replacement. Any suggestions as to what's causing this? 5.7 liter engine 2WD half-ton, dual AC, 190K miles. Engine temperature fine, fuel pump repalced about 3 months ago, same with fuel filter. Thanks.
Re: 1994 Sub "Service Engine Soon" light
Thanks, I'll try that this weekend.
OK, here's where I am:
The Service Engine light sometimes comes on, but then goes out. I red the error codes, got a "12" to show the computer was able to store codes (good) then an error code of "32" which is an EGR error. This morning I went outside, found the EGR, pulled off its vacuum hose, and attached my hand vacuum pump. It would not hold a vacuum, likely bad EGR diaphragm. I then started the Sub and pulled hand vacuum lever, but no affect, no mis-fire or stalling. So it looks like my EGR is bad, and if I can get clearance to swap it out, I will, this weekend. "Of course" I see at least two different EGRs listed for my year and model, it's a Suburban !!! |
AC Delco 214-5073 is the right EGR valve for your Suburban. I prefer to stick with AC Delco for Emission parts.
By the way, it should hold a vacuum with the engine off so it does look to be a bad EGR valve. //2000CAYukon |
I cleaned my existing EGR with spray carb cleaner, and reinstalled it. I disconnected the battery to clear error codes. I started up the Suburban, pushed in the EGR diagragm, and Sub shuddered and shook, nearly stalled, like it's supposed to (with a traditional EGR one could pull vacuum on the nipple and the same should happen). I'm going to try it and see; on a short outing last night the Service Engine Soon light did not come on. I'll update later. |
Two days later, with longer drive, Service Engine Soon light again came on, then went off again. Again the code read 32 for EGR system. Right now I'm reluctant to pay about $80-110 for a Delco EGR or pay my mechanic $200 to install same, only to find out two days later that money was thrown out the window.....
Autozone has the diags for the EGR valve and solenoid (you must register to see them). If you do have a Negative Pressure EGR (it will have a N stamped on it), it should hold vacuum with the engine off. If it does not, EGR is bad. Does EGR solenoid hold vacuum (TBI side)?
//2000CAYukon |
My EGR solenoid valve DOES hold a vacuum at the TBI side, and it does click when I apply 12 volts to it, although I didn't test it in that mode with the hand vacuum. |
