Old 08-25-2009, 12:34 PM
babycin75 babycin75 is offline
2000 Grand Prix SE Starting Problems
Hello I have two questions. The first is when I try to start the car it sometimes starts just fine and then sometimes I have to give it gas to make it start and then when you accelerate from the stop it is sluggish until you put your foot into the gas a little more and then it runs great.
The other question that I have is why does the heater/ac fan only work on 5 not any of the others. Are any of these hard to fix? I am not good at any of this so could you spell it out because I am not good at the jargon. Thank you in advance.
Old 08-25-2009, 03:54 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 2000 Grand Prix SE Starting Problems
welcome to AF
The blower speed issue is very common . You need a new blower motor resistor.
Try unplugging the MAF sensor and then start the car. If it runs better with the MAF unplugged after a short adjustment period, you need a new one. If unplugging the MAF doesn't change anything, you need to get a fuel pressure guage and check fuel pressure, as you may have a fuel pump getting weak.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-25-2009, 04:43 PM
I am sorry what is the MAF? I do not understand what that is.
Old 08-26-2009, 11:49 AM
richtazz's Avatar
MAF= Mass Air Flow sensor
Here's a link to our tips and maintenance subforum, and a pic of where the MAF is located.
http://www.automotiveforums.com/vbul...d.php?t=746374
Old 08-31-2009, 02:04 PM
GPFred GPFred is offline
Something to look at as well would be the fuel filter. If you frequently run your tank down near empty, you're picking up junk from the tank bottom and it plugs up the filter. I had a similar issue and the filter change cured it. Got to do it again here before winter sets in. Its overdue and starting to show those symptoms again. Good Luck.
Old 09-08-2009, 06:23 PM
Firstymer Firstymer is offline
What is the procedure or process in changing the fuel filter because I am experiencing the same problems with my 00' GP SE v6 126+KM
