Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 04-04-2003, 08:22 PM
boodie boodie is offline
Wiper Arm Tapered Hole...
Should the internal wiper arm tapered hole (where it mounts to the gearbox) be grooved???
We had an ice storm last night/today, and while driving home (after chipping most of the ice away) a chunk of ice got caught under the pass side wiper arm and threw the wiper synch off...
When I got home & took it off, the wiper arm tapered hole has an almost polished, smooth look...Where most of the wiper arms I've worked on were grooved...
I won't be able to get to a dealer till the middle of next week (left the wiper arm off), but does anyone know now if I need a new one or is this one still usable???
Old 04-05-2003, 12:50 PM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
The splines on the shaft are very very fine, more of a "grip" surface than an actual indexing mechanism, but you might have stripped them.
Brent
Old 04-05-2003, 03:03 PM
Originally posted by OffroadX
The splines on the shaft are very very fine, ...
The shaft splines (couldn't remember that word!) seem OK (after I clean out the amuninum shavings), but is the wiper arm also splined to match??? Or is it supposed to be smooth???
Old 04-06-2003, 11:56 AM
Yes, they are. Sounds like you might have stripped 'em.
Brent
Old 04-06-2003, 12:10 PM
Xcanuk Xcanuk is offline
Send a message via AIM to Xcanuk Send a message via Yahoo to Xcanuk
I haven't checked and I can't remember, but isn't there a plastic insert inside the wiper arm that matches the spindles ?? 2$ swap and it should be good to go.
Old 04-06-2003, 02:14 PM
Not on this arm...Steel shaft on gearbox; aluminum arm...No insert...
Guess I need a new arm...
wiper arm trim piece auroradream Aurora 0 01-11-2004 06:12 PM
How do you remove the wiper arm to get to the motor? jberenyi Caravan | Voyager 1 01-08-2004 11:46 PM
Looking for Suzuki Swift Wiper Arm HoosOnline Swift 1 12-24-2003 12:22 PM
Anyone have a wiper arm off of a 82 sentra or close to it? bhami8287 Sentra | 200SX (USDM FWD) 0 05-21-2003 01:04 PM
