Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-24-2009, 08:46 PM
earlpitts earlpitts is offline
Exclamation 97 Eclipse Missing on 1 and 4
97 Eclipse Non Turbo 2.0 Missing on 1 and 4 cylinders. Have changed cam sensor, crank sensor, coil pack, plugs and wires. Any suggestions on where to look next?
Earl Pitts..... Proud To Be An Uhmerikun!
Old 08-24-2009, 09:53 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 97 Eclipse Missing on 1 and 4
Are you sure its a spark issue and not fuel? Check all of the wiring come from the coil pack and make sure none of it got burnt on the EGR pipe.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-25-2009, 04:51 AM
I have checked all wiring even tracing the wires from the coil pack to the ECU and checking with an ohm meter. And yes, there is no spark on 1 and 4.
Thanks
Old 08-25-2009, 08:46 AM
Holset powered 420a
Well it seems like you have covered pretty much everything but the ECU. I hate telling people to replace the ECU since its such an expensive piece and no one can be sure if that is the problem. But you have seemed to eliminate everything else. I cant think of anything else that could cause spark to die on just 2 cylinders. Did this just randomly happen one day or could something have caused it?
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-25-2009, 08:43 PM
It just started missing one day. I do have an ebay ecu that arrived today. I will try that tomorrow. Thanks
Old 08-25-2009, 09:01 PM
ned032002's Avatar
ned032002 ned032002 is offline
Did you try the power transistor?
Old 08-25-2009, 09:16 PM
No I have not. Im not really sure where its located or what it looks like. Where would it be located on a 97?
Old 08-25-2009, 09:58 PM
Holset powered 420a
The 420a motors do not have power transistor packs.
Ned I need one to MS to control the spark.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-26-2009, 08:41 PM
It was infact the ECU...runs great now...but I did do a stoopid thing... the ECU was for an automatic car....dOh!
Old 08-26-2009, 10:25 PM
Holset powered 420a
Well thats good, glad you got it fixed. An auto ECU should work the same just have a lower rev limiter. And you may get a CEL for some auto tranny shit. But other than that the car is drivable at least.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-27-2009, 06:36 AM
ned032002's Avatar
My bad about the transistor, thought I'd throw it out there anyway.
