How to Replace Front Wheel Hub Assembly
This seems like it should be an easy thing to do. Does anybody have any tips or advice on replacing the hub assembly? I have a 2003 Silverado 1500. Any info will be greatly appreciated.
Re: How to Replace Front Wheel Hub Assembly
also you must give a better description of you vehicle... |
You will probably need a T55 Torx,15mm socket,18mm socket,22mm socket 1/2 drive plus tools to remove the tire. A 35mm Impact for the front bearing.
http://www.autopart.com/tools/toolsmain/tool/T_4300.htm as you are replacing the hub a big hammer will work. Unplug the speed sensor. Basically remove the tire,caliper,caliper mount, 3 bolts which hold it on. Older units nut torque 156 ft pounds. |
I just did this on my 2000 Silverado 1500 4WD, it'd easy. take off wheel, unbolt caliper (2 bolts), hang it out of the way with some wire or a bungee cord. Unbolt the ABS sensor and then undo the three bolt that hold the wheel hub assembly. One tip, before you jack up the truck, loosen the wheel bearing nut (35 mm socket).
Bert
My Truck: 2000 Silverado,, Z71 5.3 Ext. Cab, Long Bed Original motor + transmission! As of 3/21/14, I'm at 266,300+ miles! My wife's Truck: 2005 F150 Lariat CrewCab (Way nicer them my truck!) |
Did you already buy the bearing/hub ? I'm done buying very expensive parts finding out they last just as long as their cheaper counter parts. i.e. a $300 AC Delco Fuel pump that lasted about 8 months. I found my bearing/hub on Ebay for $45.
Just a thought. Bert
