Old 08-24-2009, 03:03 PM
WheelerXp WheelerXp is offline
Lightbulb Cruise Control Sticks
Just recently fixed my cruise control (noticed the hook was off the throttle line) and glued it back on. Now every now and then when i get off the parkway, and come to a stop i notice the car running louder, and i need to put the brake really hard down to keep the car from jack rabbiting. When i turn the car off and on again, everything is fine and clears out.
Is this a normal problem with a quick fix, or a 1,000 investment. lol
Old 08-24-2009, 03:42 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Cruise Control Sticks
Check that the PCM is getting an input from the brake switch.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
