Old 08-23-2009, 10:04 PM
DennisG_02Silvy DennisG_02Silvy is offline
2002 Silvy 4.3 won't start
ok so first the we thought the fuel pressure regulator went out since its been acting up for the past year or so. we changed it tuesday night. truck still wouldnt start. checked in see if we were getting fuel through the filter, yes. wednesday comes around so we were looking into the ignition, of course i had to work all day so diditn get to really check it. put a new rotor and cap on, checked to see if coil was getting spark and checked ignition control module. All was getting spark. We went back to the fuel system, the fuel pump wasnt working properly. so i bought a new one today, just got done installing it, and it works. still wont run.
it"ll want to run if we spray starting fluid in, but its like its not getting enough fuel. we then pour a little fuel down the throtttle body, then start it and it runs for alittle then cuts out. so i know its getting spark, just prolly not any fuel. Any suggestions? thanks
also just rplaced fuel pump second time this week and im still reading 37psi
Old 08-23-2009, 10:11 PM
j cAT j cAT is offline
Re: 2002 Silvy 4.3 won't start
check voltage at the fuel pump...check ground at the fuel tank frame rail,,replace the fuel pump relay,,fuel pressure is too low,,on the 4.3L I don't have the spec off hand but 37 is a problem..
what is the pump manuafacturer,,,and was it the exact same pump as you removed ???
Old 08-23-2009, 10:22 PM
cramer_77 cramer_77 is offline
check the 8th digit in your VIN, if it is a W specs should be 60-66psi, if it is an X it should be 55-62psi. you might replace your filter it could be clogged up with dirt just enough to weaken the pressure output before it gets to the engine. hope this helps
01 Silverado 2500HD, HID lows and highs, cold air kit, leveling kit, brush guard, dual flowmaster outlaw mufflers, 5% windows.
Old 08-23-2009, 10:40 PM
the engine code is a w
i just replaced the fuel filter again bc i had to when i warrantied the fuel pump a few hours ago, and the fuel pump is a delphi.
yea i thought about checking the voltage but i dont have a volt meter.
what plug am i supposed to check it at? theres two going to the pump
thanks
Old 08-23-2009, 10:41 PM
and i also changed the relay and checked all fuses. theres also no engine codes
Old 08-23-2009, 10:51 PM
the pump was original until this past thursday. replaced it with a delphi. wasnt getting enough pressure so i figured it could of been a bad pump so i warrantied it to for another and pickin up bout the same psi
Old 08-24-2009, 08:54 AM
so replacing the pump you still get the same low pressure readings ????
if that is the case I would suspect a fuel line restriction....see if the lines are damaged...
also hook up a hose to the fuel pressure test port and direct the fuel into a gas container to see if the flow is constant and solid flow with the fuel pump held on...
Old 08-24-2009, 09:36 AM
yes there the same reading as the previous fuel pump i installed.
Old 08-25-2009, 08:09 AM
if you plan on working on vehicles you must have a meter to check these things out...
the other area if the voltage is correct at the pump....would be internal connections to the pump of voltage/power and or the suction line defective or not sealing so as to be able to draw fuel into the pump..
