Old 08-23-2009, 09:13 PM
ned032002's Avatar
ned032002 ned032002 is offline
Easy question for someone that knows the answer
Is the EVO 3 16G a direct fit on a 1G GSX w/ a S16G already installed? What other modifications need to be done to work properly?
Old 08-23-2009, 09:34 PM
steviek's Avatar
steviek steviek is offline
Re: Easy question for someone that knows the answer
yes
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 08-23-2009, 09:35 PM
steviek's Avatar
same with the forced performance 18g
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 08-24-2009, 02:57 PM
ned032002's Avatar
Well now for the relevance of my question, looks like my turbo seals are shot. What do you guys suggest I do? It costs so much to rebuild, just a few more dollars I can just buy a new bigger turbo. I have no cash for a repair like this, what should I do?
Old 08-24-2009, 03:52 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Why not rebuild it yourself?
you could do it for like 60$. And if you dont want to there is a guy on tuners that does it for 125 I think and does an excellant job.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-24-2009, 06:13 PM
ned032002's Avatar
Where do I get the parts I need to do it? Won't it need to be balanced and what not? I can also see some oil on the outside of the turbo, like when looking at the whole turbo set up it is right to the left side of the oil inlet. I don't mind doing it myself just what do I need to buy to make this happen?
Is this the kit I'm looking for? Scroll down to the TD05H $89
http://www.gpopshop.com/mitsubishikits.html
Old 08-24-2009, 06:48 PM
Holset powered 420a
Yea thats all you need. And as for balencing, I believe each part of these turbos is balenced seperately. I have taken many turbos apart and even swapped wheels between turbos without every balencing them afterwards. And they run fine. Now I would make your wheels before you remove them and try to put them in the original spot just to be sure. Also make sure you know which way you compressor nut is threaded. Some 16g turbos have left handed threads.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-24-2009, 06:50 PM
ned032002's Avatar
And here's a really good write up on what to do
http://www.austarion.com/tech/turbo.pdf
Old 09-03-2009, 07:39 PM
ned032002's Avatar
Good new is that the turbo seals are not blown, I'm a product of my own destruction apparently. I connected the valve cover breather line right up to the MAF housing in one of the inlets. That was causing oil to be sucked through the line and blown through the turbo, that explains the smoke out the exhaust.
Old 09-03-2009, 08:59 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Easy fix.
As for the rebuild for the future, they are easy to do. For balancing, you just mark everything as it's coming off or take pics of how everything looks and where it's all at. Piece of cake.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-05-2009, 11:28 PM
ned032002's Avatar
I contacted that guy from Tuners, if I ever need it rebuilt I probably will just have him do it.
