Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-23-2009, 08:06 PM
Jeffesong Jeffesong is offline
Rebuild differential on 85 caprice
Hello,
It looks like I might need to rebuild the differential on my 85 caprice. Its only got 185k miles on it./ Before I do I want to change the differential fluid. Easy enough to do but I am not sure of what type of gasket to get to replace the old one on the differential cover. Its a 10 bolt, I know this much. What else will I need to know?
Old 08-23-2009, 08:33 PM
rhandwor rhandwor is offline
Re: Rebuild differential on 85 caprice
Look for a small metal tag under one of the bolts. Take this number with you to the parts store. You can always clean the cover and take it with you.
Counter help isn't as experienced as they used to be.
Old 08-23-2009, 10:44 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Originally Posted by Jeffesong View Post
Hello,
More than likely your car has a 7.5" on it. The 7.5" cover looks like a 'round square', while the 8.5" is a true oval shape.
As for myself, I don't use gaskets anymore on diff covers - I use "Permatex The Right Stuff". It seals better.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-27-2009, 03:36 AM
LTZShane LTZShane is offline
I have heard that on the 8.5 its best to use a gasket due to some holes designed to help move lube to the wheel bearings.Sounds like the fel-pro gasket is the prefered one.Not meaning to disagree with silicon212 I found the info on a 9c1 site.
Tags
differential
