Go Back   Automotive Forums Car Chat > Land Rover > Range Rover | Range Rover Sport | Evoque
Old 08-23-2009, 05:00 AM
T-Ball T-Ball is offline
Need help! Range Rover alarm has locked engine
I have recently moved overseas. When my 2000 Range Rover arrived I drove it a few days with no problems. Suddenly the electronics started doing funny things: intermittently stuttering (radio, a/c, etc), the gas tank door would pop open, etc. I parked the car and when I returned to the car the car alarm sounded after opening the the unlocked driver side door. I attempted to start and the alarm by-passed the ignition system and would not allow me to start the car. I used the factory provided reset sequence in the door (using the key, turning left and right a set number of times). This worked and the vehicle started. I left the vehicle alone, satisfied the problem was fixed. Three hours later I returned to the vehicle and experienced the same thing as before. I again attempted the key reset sequence in the door to no avail. I continued to try several times with different sequences. Finally, the door mechanism simply stopped working. Now the vehicle is locked and I am unable to even enter the vehicle.
Thoughts, recommendations...
Old 08-23-2009, 05:29 AM
MoW MoW is offline
Re: Need help! Range Rover alarm has locked engine
Something similar happened to me when the battery charge was very low.
www.ministryofwheels.com
Range Rover III 4.4
