Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 08-22-2009, 08:38 PM
jim Yonkin jim Yonkin is offline
Check Engine light - Need to pass inspection
1999 Avalon - 185k mile
Check Engine light has been on for six months. Have been driving with no noticable problems. Not looking to put money in a car with almost 200k miles.
Now I need to pass Texas state inspection. I understand that a check engine light is an automatic fail. Last time I had the car in I was advised that I had three codes:
P0402 - Exhaust Gas Recirculation Flow Execessive detected
P1411 - EGR Valve Position Sensor Circuit
P0446 - Evaporative Emission System Vent Control Circuit
Can someone help me understand if one or more of these is the source of the check engine light and if it is high cost repair?
Old 09-01-2009, 10:27 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Check Engine light - Need to pass inspection
The check engine light will be set when any trouble is detected in the emissions control system. Is the rest of the car kept in good condition and well-maintained with routine service?
If it is the EGR valve, you might be able to clean it and get it working properly. If not, they run about $200 for the part itself.
Bear in mind that Texas inspects vehicles yearly, so you'll have to fix it eventually. If all you have to spend is $200 on a 10-year old Av then you've done well...beats a car payment and higher insurance EVERY month on a new car.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 09-01-2009, 02:57 PM
whopperdad whopperdad is offline
im going through same thing now. Have heard it is charcoal cannister and vsc switch vale comes as 1 assy. 340.00 bought one today need to know if you have to drop tank to access. I hope someone here knows. Thanks in advance. Car is 99 Avalon 98,000 miles.
Old 09-03-2009, 01:00 PM
jdmccright's Avatar
The RustBuster
The canister appears to sit in between the fuel tank and the rear axle cross-member...looks easy to get to. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
