Old 08-22-2009, 02:18 PM
Richard S Richard S is offline
loose steering
I have a 91 Silverado. It has tilt steering and wobbles. I have been told the 4 bolt down in the column are loose. Is it a big chore to fix?
I have a pivot tool on order from snap on. I also found the bearing at the top is loose seems to be bad. Does anyone know where I can get the upper and lower bearing besides the dealer, I have checked at several of my local supply houses. Thanks for any advice. I did read an article on the web about repairing it.
Old 08-26-2009, 06:46 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: loose steering
Theyre not bad, just remember to put lock tite on the screws and continuously check to make sure that your high beams work.
Also you will need a steering wheel puller.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 09-02-2009, 08:52 PM
Re: loose steering
Thanks, I got it fixed. Just had to take my time and patience. I thought I was going to break my pivot puller though. One came out easy and the other would not budge. I used a screwdriver from the back side while the puller had tension and pried on it. It was just enough to get it started. Thanks
