Old 08-22-2009, 11:30 AM
Judi220 Judi220 is offline
Power Steering Problems - 2002 Chev Cavalier
I was told I had a leaking pump six months ago even though there was no obvious leak. Since then it has been replaced twice as well as a hose and a seal and continues to leak. I am at my wits end. Anyone out there that can relate or pass on advice? Any help would be appreciated.
Old 08-22-2009, 02:44 PM
racerxpl racerxpl is offline
Re: Power Steering Problems - 2002 Chev Cavalier
You say there is not obvious leak? You are losing fluid? Check the steering unit itself.
Old 08-22-2009, 04:00 PM
maxwedge maxwedge is offline
A990 racer
Wrong forum this is going to the Cavalier forum below.
Old 08-22-2009, 07:40 PM
jadi929 jadi929 is offline
did u make sure it was power steering fluid or somthing else?
Old 08-24-2009, 04:02 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Is a shop doing this? How was it determined that the pump was leaking if there was no obvious leak?
Sometimes the rack will leak from the seals and the fluid gets held in the dust boots, poke a very small hole in the bottom of both and see if fluid runs out. If no fluid, clean the boots and seal the holes up with RTV sealant.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
