Old 08-22-2009, 09:10 AM
lowside lowside is offline
1996 Chevy Cavalier No Start
My 1996 Chevy Cavalier with the 2.2 engine won't start with no spark, I have changed the crank position sensor and I have had the ignition module/ coil checked and both were ok. A mechanic from local chevy dealer said that these cars are known for having electrical issues between sensors and pc. Main reason the pc harness runs under the radiator.
So I started with the crank sensor it has three wires coming from the sensor. One wire is red, one is pink/ black, the other is blue /white, I have trace them back to the pc and found that the red wire does not have continuity from sensor to pc and according to the haynes service booklet it connects at pin 24 on the pc.
At first, I thought maybe it was a fuse but all of them checked out ok.
The other two wires have continuity and are used to get a 7x reference signal.
The question that I have is about the red lead since there appears to be an open circuit from the crank sensor to pc, in the service book it looks like some type of relay from sensor to pc, what role does it play in starting the car?
Old 08-24-2009, 03:37 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 1996 Chevy Cavalier No Start
Post a picture of that wiring diagram if you can. I don't remember ever seeing anything that looks like a relay in a sensor circuit.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 08-25-2009, 09:17 AM
xFatcatx xFatcatx is offline
Sorry lowside I have no idea what your issue is, but I was curious on how you went about changing the crank sensor? I did it last night on my sisters 98 2.2l auto and it was a pita.
Old 08-29-2009, 12:32 PM
J-Ri's Avatar
Either from the top or remove the RF wheel and go from the side. I do a combination of the two... it's a PITA whatever way you do it. '98 is actually a bit easier than the older ones, on the older ones you have to remove the coil packs and ignition module to get to the crank sensor.
Old 08-31-2010, 01:45 PM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Check that the ignition module under neath the coils have 12 volts going to it. It will be the white wire with black stripe.
Old 09-01-2010, 08:57 AM
Problem solved, I forgot to connected up the lead/ harness that ties in the crank position/ cam sensor and knock sensor to the pcm. My original problem was a open wire from pcm to crank position sensor, so I went to the junk yard and got the identical harnesses to make a test harness to check all of the connections for continuity. Somehow during testing I forgot to connect it back in.
Then I received a reply from manicmechanix, to effect of telling me to check the ignition module for pluses. As I proceed to check the module I noticed the a wire hanging, as soon as I plugged the leads together and cranked the engine the module sparked.
Thanks manicmechanix
