Old 08-22-2009, 06:20 AM
tsage tsage is offline
Smile Ford trouble code 1401
Trouble Code P1401 Diff Pres Feedback EGR Circ High Input. I replaced the DPFE and it did not cure the problem. What other possible causes should I look for?
Old 08-23-2009, 06:44 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Ford trouble code 1401
Check the passages behind the EGR valve. If it is plugged, it will set that code.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 08-27-2009, 10:16 AM
Smile Re: Ford trouble code 1401
Disconnected and plugged vacuum line from EGR valve. Truck ran better.
Put length of hose on EGR valve, turned up 2000 RPM and applied small amount of vacuum (by mouth) and engine started to stall. This would seem to indicate that the EGR valve is working and passages are clear.
Truck seems to run just a little rough. Cleared trouble code. Will see what happens next.
