Old 08-22-2009, 01:34 AM
spideyman's Avatar
spideyman spideyman is offline
Anodized Purple
Hello all,
I was wondering if anyone knows the best way to replicate purple anodize. I know how to replicate blue and red, but I havent seen purple. If I were to mix transparent red and blue together would that work? If anyone has an good ideas I would be most appreciative.
Thanks
"Artificial intelligence is no match for human stupidity."
Current builds:
1950 Chevy Street Truck: http://www.automotiveforums.com/vbul...d.php?t=953839
Supra Drifter (FINISHED): http://www.automotiveforums.com/vbul...66#post6109966
1966 Volkswagen Beetle "Showroom Stock": http://www.automotiveforums.com/vbul...d.php?t=967968
1/12 Datsun 240Z: http://www.automotiveforums.com/vbul...90#post6415290
Old 08-22-2009, 08:16 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Anodized Purple
That will do it. I often mix I would definitely airbrush it on, and spray all parts that will be that color at one time- it will be virtually impossible to match the color again later. But it should look great. What are you 'anodizing'?
PHOTOBUCKET SUCKS
Old 08-23-2009, 09:52 PM
spideyman's Avatar
Re: Anodized Purple
Various engine parts, pulleys, cam gears, turbo intake horn, blow off valve, ect....
Current builds:
Old 08-24-2009, 08:19 PM
935k3's Avatar
935k3 935k3 is offline
Re: Anodized Purple
Mixing Tamiya's clear red and blue did not work it gets brownish. What did work was starting with a silver base I then airbrushed a light coat of clear red(not to many coats) then go over that with a coat or two of clear blue. It looked far better than just mixing the two then spraying.
Old 08-24-2009, 08:21 PM
drunken monkey's Avatar
Razor Sharp Twit
Re: Anodized Purple
would regular purple drawing ink work (through an airbrush that is)?
may need to clear it afterwards though because drawing ink would likely crack and flake after a while.
AF's Guidelines
Read them.
Old 08-24-2009, 09:04 PM
dmacb's Avatar
dmacb dmacb is offline
Re: Anodized Purple
House of Color has a candy purple. Black Gold sells it online in 1 oz jars. I've used it and a thinned coat would provide the exact color you need, but it is lacquer.
Old 08-25-2009, 02:24 AM
Asmenoth's Avatar
Asmenoth Asmenoth is offline
AF Premium User
Re: Anodized Purple
You might mix it with Future to prevent the flaking.
Do you know how fast you were going son?
No Officer, the speedometer only goes up to 85.
Old 08-25-2009, 04:17 PM
rsxse240 rsxse240 is offline
Re: Anodized Purple
What I've done in the past, is mix (sorry guys I'm a cheap skate) Testors Boyd's high gloss clear with various opaque colors to create candy top coats. Just find some Testor's enamel Plum Crazy and add as many drops of it to the jar of clear as it takes to get your desired opacity. Now the more opaque you make it the fewer coats it will take to coat your part.
This really works! oh and it works well for spray on window tint too.
