Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-21-2009, 11:03 PM
Elkad Elkad is offline
95 3.8 5spd starts fine cold, no spark when warm
Friend's 95 3.8L 5spd.
Starts instantly when cold, and will run all day just fine. Once the motor is warm it won't restart, it cranks fine, but has no spark. Have to let it cool down for an hour or more before it will start again.
He has changed crank sensor, cam sensor, coil pack. Ground near battery on fender looked questionable, so we fixed that.
Only code is O2 sensor heater
TIA
Old 08-22-2009, 09:54 AM
ronaldk's Avatar
ronaldk ronaldk is offline
Re: 95 3.8 5spd starts fine cold, no spark when warm
You may need that 02 sensor but that will not kill spark. most likely ign module. ICs and transistors are heat sensitive and usually work cold then crap out when hot
Old 08-22-2009, 12:19 PM
Isn't the ICM part of the coil pack?
Old 08-22-2009, 05:33 PM
ronaldk's Avatar
I looked up at napa and coil is seperate from ICM.Autozone has great pixs of these parts
