Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 08-21-2009, 11:05 AM
wlsnoops wlsnoops is offline
Driver Information Center
The temperature readings has been off about 10 degrees lately. I thought I would check to see if a sensor might be dirty, but I don't know where it is located.
Would that cause it to show an incorrect temperature reading?
Thanks.
Old 08-21-2009, 02:44 PM
roadrunner2 roadrunner2 is offline
Re: Driver Information Center
Thanks.
The remote ambient temp thermometer on my 2000 Silo was in front of the rad on the drivers side.
I found that when the vehicle sat in the sun for awhile it would read higher than the actual temp at the time.
After driving for a bit, the reading came down and when I found out the actual temp on the radio, I checked the DIC (Driver Information Center) and saw the temp read correctly.
The problem with doing nothing is not knowing when you're finished.
Old 08-21-2009, 03:17 PM
I guess I should have been more explicit with my explanation. The temp is about 10 degrees cooler, even after sitting in the sun. Thanks for the location info. I'm going to check it right now.
Old 03-09-2010, 08:35 AM
depalma depalma is offline
Smile Re: Driver Information Center- temp sensor
I replaced the ambient temperature sensor and it fixed the problem.
However, contrary to this thread, I found the temperature sensor to be located on the PASSANGER side in front of the radiator. ( not the drivers side) I own a 1999 and a 2003 SILHOUTTE and found the temp sensor to be located in the same position for both cars.
Old 03-09-2010, 08:26 PM
I'm not going to doubt you as it is entirely possible the sensor on my GLS had died and replaced to the other side.
I was the second owner.
Tags
center , computer , dic , driver , information
