Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-21-2009, 01:33 AM
2dooreighty5 2dooreighty5 is offline
new headers......
i just got those headers on and the car is sounding great once i give it some gas but when its at idle its running rough.... timing is on but the motor is shaking alot..... my fring said it was because there was so much air leaving the motor... its a stock intake and carb on a 305.... should i replace the intake....
Old 08-21-2009, 11:22 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: new headers......
You will have to rejet the carb. The headers will require a richer mixture. If you have access to a dwell meter and spend a little time researching something I've written here on how to adjust the M/C-IAB circuits, you can adjust the idle air bleed to richen it up a little in the idle circuit - don't mess with the idle mixture screws. Keep in mind this only affects idle and off-idle (low speed cruising etc), so you will still need to rejet.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
