Old 08-21-2009, 02:33 AM
Tobey Tobey is offline
Only passenger side blows cold
My AC hasn't been working well at all the last few months, so I bought a gauge to check the pressure. Gauge said the low side was over 100 PSI (which can't be good...). After I pulled the gauge off, the valve started leaking and I couldn't get it to stop. It did this for a few hours and finally stopped on its own. I checked the pressure again, and it's holding at 30 PSI.
On the plus side, the AC works great now, engaging the compressor doesn't bog the engine down anymore and it blows ice cold... but only on the passenger side. Why is this happening? Is it a blend door issue, or is my pressure now too low?
Old 08-22-2009, 07:28 AM
olds409's Avatar
olds409 olds409 is offline
Re: Only passenger side blows cold
Ok Tobey.
You have a bad servo motor.Is under the dash.Not too hard to replace,but a pain in the neck.
Old 09-29-2009, 05:44 PM
Follow up in case anyone else has this problem... it was indeed becuase my pressure was too low. Charged it back up and drivers side is ice cold.
