Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-21-2009, 12:39 AM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
vc gasket...felpro
hey if youll scroll down on this page, and look at the 4th choice...the 420a gasket...
is this the highest quality vc gasket they make for our cars? felpro?
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 08-21-2009, 07:17 AM
ned032002's Avatar
ned032002 ned032002 is offline
Re: vc gasket...felpro
You didn't post a link
Old 08-21-2009, 07:44 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
It will be fine, just make sure to clean the surfaces and put silicon in the spots your suppose to
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-21-2009, 09:29 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
This.
VC gaskets aren't worth worrying about brand. Make sure to replace the plug-well and half-moon gaskets. Some kits do not include these.
Kris
2012 Genesis Coupe 2.0t
Old 08-21-2009, 12:24 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Agreed. Valve cover gasket really have no pressure so brands are not important. I have a full Felpro gasket set on my car right now, and I believe the HG is too at the moment.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-21-2009, 01:19 PM
sorry....4th one down if u still wanna check it out...
http://www.racepages.com/products/?N...t&N=4294963837
but um, guess you dont have to, but it comes with the vc gasket, and also the spark plug tube seals...thats all i need right? i can do it all myself, gotta haynes manual and all, gotta find it lol...
Old 08-21-2009, 01:31 PM
Holset powered 420a
dude are you going to order it? Just go to the parts store and pick one up.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-21-2009, 01:38 PM
Oh yeah I am, just using the sites pics as references...
I don't really need help installing it bc its a no brainer, but, I did have one other question which is relative...
Ive been wanting to replace the camshafts...its pretty much all I want to do to the head, nothing wild, just a mild upgrade...and I thought, well if im doing the vcg, I can do all this at once. My question is, ive never installed aftermarket cams, ive only replaced oem ones in class...I know how to do it, but, is there anything special I need to know about dropping in aftermarket cams? Like, do they just drop in, bolt up, and the car will run just like b4, or does it require any extra special tuning...
Old 08-21-2009, 01:42 PM
Holset powered 420a
It just bolts right in. But remember you have to pull the timing belt off in order to remove the cams.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-21-2009, 08:12 PM
Right...which im sure is a bitch
Old 08-21-2009, 08:24 PM
hey silvr,(or anybody who knows camshaft profiles pretty good)
i cant decide which is right for me? light track, mostly street, and for a car that prob. will stop being upgraded after around 400hp...
im not fluent in camshaft lol...
thanks man
Old 08-22-2009, 12:35 AM
hey when changing cam gears...is it necessary to take off the entire timing belt...or just slip it off the two gears..in other words...remove every other thing in its way to get to it?
also, does having a "high performance'' timing belt make any difference?
I saw on a forum for ford focuses(google took me there) if you remove the belt completely, you have to do all this extra work, when if all your doing is changing the gears, you can just slip it off...is this the same for our cars? is it a pain in the arse?
Old 08-22-2009, 07:57 AM
david-b's Avatar
Dave is THAT guy
im not sure if you can just slip the belt off. Its under a lot of tension so I dont think you can. Seems to me the tensioner would have to be pulled and then timing reset. As for the cams it depends on what you want to do. Bigger cams make the car harder the drive. My Crower Stage 2 lost power in the low end power band. It also depends on if youre upgrading anything else in the head like the springs.
Mozilla/5.0 (compatible; Teleca Q7; Brew 3.1.5; U; en) 240X400 LGE VX9700
Old 08-22-2009, 11:32 PM
yeah ok...
i know with the camshaft im looking at getting...it says it has to have the springs and retainers upgraded...
so, you dont htink i need to even change the cam gears for the purpose of only seeing 400 hp?
Old 08-23-2009, 09:54 AM
david-b's Avatar
Dave is THAT guy
Changing out cam gears will do absolutely nothing if you don't know how to adjust them properly.
75 Monte Carlo
