Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-21-2009, 12:03 AM
dndboyd dndboyd is offline
95 Eagle Talon Esi hesitates on throttling
I have a 95 Eagle Talon Esi 2.0 manual It takes like 3-5 times of turning it over till it starts and then it idles real rough. After it idles for a bit it will stay idling but when you push the gas pedal down it bogs out unless you do it really slow and then it will rev up. I have replaced the fuel filter and checked for air leaks. Any other ideas would be greatly appreciated. Thanks
Old 08-21-2009, 12:21 AM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
Re: 95 Eagle Talon Esi hesitates on throttling
what shape is the engine in?
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 08-21-2009, 12:32 AM
The engine was well taken care of with regular maintenance but it does have 250k on it
Old 08-21-2009, 01:43 AM
i wonder if compression might be the problem...
ive had some funny things happen in school messing around with compression issues...
you should check it unless someone else here tells you different...
ive heard of similar symptoms...
Old 08-21-2009, 01:35 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Welcome to AF. Have you changed your spark plugs and wires at all recently? If not, do that and make sure they're gapped properly. I would also run a bottle of fuel injector cleaner through a tank of gas and see if that helps any too.
A compression test would also help in diagnosing if it's an internal problem, althought right now it doesn't sound like it.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-21-2009, 02:51 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Do you have a check engine light on?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-18-2009, 05:31 PM
I replaced the ignition coil pack, wires, plugs, TPS sensor, IAC sensor, Camshaft sensor, MAP sensor and the EGR assembly and it still has the same problem. Grrrr........
