Old 08-20-2009, 08:59 PM
salvadorm salvadorm is offline
po715
P0715 Turbine Shaft Speed (TSS) sensor circuit malfunction
I get this code and i need to know where to locate this sensor so that i can fix it
Old 08-21-2009, 09:12 PM
wiswind wiswind is offline
Re: po715
From my description under "OBDII CODES" sticky post
"This sensor is on the driver's side of the transmission case.
When you remove the driver's side tire, look in where the drive shaft enters the transmission.
The TSS is located on the case, at about the 11:00 position.
It is held in place by 1 bolt."
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
