Old 08-20-2009, 08:28 PM
hufhouse's Avatar
hufhouse hufhouse is offline
Blower fan resistor?
1996 Grand Am SE 2.4 with air conditioning
Blower fan doesn't work on highest setting. All other settings work. (Opposite of the normal resistor problem!)
I've already replace the blower fan.
Still think it's the resistor?
Old 08-20-2009, 08:32 PM
3100 3100 is offline
Banned
Re: Blower fan resistor?
you are right, it is.
Old 08-22-2009, 12:42 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
On setting 5 it usualy bypasses the resistor and uses direct current(12vlts) to the fan.
Did you check the blower motor fuse ?
And I'd check that the plug in to the resistor is fully connected.
1999 Grand Am SS 3.4 OHV
Old 08-22-2009, 01:13 PM
doctorhrdware doctorhrdware is offline
Check out what Xero said to. When mine went out I found the connector on the resistor and from the ac/heat control head was melted. So that could be a possibility.
Old 08-22-2009, 01:39 PM
Banned
my bad it is not resistor, xi is right I just checked the diagram you have 4 speed settings and the 4th speed bypasses resistor using blower motor relay and blower motor 30 A fuse. So check both Blower motor relay right rear of engine compartment and (that is going to be your left side when facing the windshield, you will see all the relays and look for the one that has this wires (black, brown, orange, dark blue and purple) check if you have battery (ignition key off) voltage at the orange wire when you disconnect the relay if yes, replace the relay, if not chekc the HVAC. BLO. MOT. fuse 30A
Old 08-22-2009, 02:10 PM
oops! I forgot this model only went to 4 on the blower.
Old 08-22-2009, 02:22 PM
Banned
S. happens. I did even worse by telling the guy to remove the plastic covers around the steering wheel to find the security connector. Totally forgot that the ignition cylinder on 99+ is on the dashboard.
Old 08-22-2009, 07:09 PM
hufhouse's Avatar
Well, I changed the resistor because I'd already ordered one. No worries...it didn't cost much. And, you all were right...it didn't fix the problem.
So, I took 3100's advice and checked the fuses and relay. I checked the fuses first, because that was easy to do. Both fan fuses were ok. (Yeah, I know I only needed to check the one outside, but I'm just being fussy.)
Next, I found the correct relay and removed it. As soon as I unplugged it, I knew I had a problem. The plug hole corresponding to the orange wire is melted. The relay LOOKS fine, but I don't know whether or not it actually works.
My new problem is figuring out how to fix the plug. Can I get a new one? Can I fix the old one?
Any ideas? It's really melty. They plastic is ok, but the metal part is pretty much gone.
Old 08-22-2009, 09:32 PM
Banned
you can find new one maybe in auto zones, but if not then just memorise where each of the wires connects and just buy 5 of those separate (FEMALE) connectors that are correct size and then you can plug them in separate one by one. (they come in different colors: red, light blue, yellow etc.) Home Depo has them.
also melted wire tells me that there could be short. Did you check voltage at orange wire, since there are two fuses, one for bypess one for resistor? Maybe fuses are OK, but there could be then open in orange wire somewhere. Also for the bypess make sure it is 30A just in the case that someone did not install bigger fuse. Then disconnect that fuse (30A) use dovom, set it to continuity test, put one lead to orange wire and the other test lead to any ground just to test for short to ground. If you hear a beep it is shorted somewhere. Or relay's is rusted and creating more resistance and pulling more amps than necessary thus heating up the wire. You will still have to replace relay.
Old 08-22-2009, 10:14 PM
That is what happened to the connector on my GP. It was all melted, the black and orange were melted also. It sounds like the blower motor may be draw too much current. Is or was the blower motor squealing, if it was that may be the reason why there is melted wires.
Old 08-22-2009, 10:59 PM
Banned
Since you already replaced the blower motor it is possible that the connector got melted during the old blower motor. If your 4th speed did not work since then then I wouldn't worry much just replace connector, but if the 4th speed quit working after new motor was installed then I would worry about what doctor and I are saying.
Old 08-23-2009, 02:56 PM
hufhouse's Avatar
I replaced the relay today and the blower works on HIGH.
I didn't do any diagnostic testing.
I'm a little concerned that HIGH might have stopped working AFTER we replaced the blower motor. If that's the case, I'm hoping it was just because the relay was about to go anyway. We'll see how the new relay and new blower get along. Hopefully, everything is ok.
Thanks to everyone for your help. I don't think I would have ever thought about that relay if someone hadn't mentioned it.
Old 08-24-2009, 06:56 AM
hufhouse's Avatar
Well, that lasted for about two hours.
My son informed me that the blower isn't working on high again.
Guess this isn't going to be so simple after all.
Old 08-24-2009, 07:27 AM
Banned
do the tests that I suggested above, you could have shorted orange wire.
Old 08-26-2009, 08:35 PM
hufhouse's Avatar
I did the test that 3100 recommended, and there's no short in the orange wire. No continuity with the fuse pulled. Just for fun, my son kept plugging and unplugging the fuse, making the tester buzz...so, we're sure there's no short circuit. :-)
I'm wondering if maybe I just got a bad relay from AutoZone that conked out soon after I plugged it in. I think tomorrow night, I'll see if I can exchange it and see if a new one lasts longer.
When I replaced the blower fan, I bought an aftermarket fan from RockAuto.com. It was listed for the 1996 Grand Am SE, though. Hopefully, the blower fan isn't somehow causing the relay to blow on the highest setting. It works fine through the resistor.
That's my story so far.
Any new ideas?
