Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-20-2009, 07:33 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Some bad news.
This is the first time my car has sort of "failed me" in a way. I came in my driveway yesterday, got out of the car, and stopped to look at what was a streak of tranny fluid down the whole length of my 50 foot driveway. It wasn't a fatal occurence though. I think its just the seal between the tranny/engine or the one between the torque converter, something like that anyway. I think when i was slowing down in the driveway the fluid sloshed forward and escaped through the cracked gasket. So while my cars in the shop i'll have my 1-2 shift problem fixed which is also good. I just hate not having the thing but i have no choice.
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 08-21-2009, 11:07 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Some bad news.
You've been burning out on too many emachines keyboards!
Seriously, it sounds like the front pump seal went bye-bye and this was an issue on '83s. What happens is that the drainback hole in the pump is not large enough, and pressure will build between the seal and the pump and eventually, this pressure pushes the seal out and then you get the red driveway.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-21-2009, 12:50 PM
bhw33191's Avatar
Re: Some bad news.
Haha. I got a call today and they said i need a whole rebuild. I think i did too because (say on the highway) the transmission would shift down and then literally 5 seconds later youd feel it kick into gear which i'm assuming is a bad clutch. They're replacing my torque converter too and giving me heavy duty (what i think are accumulator) springs. The guy said how this tranny is tuned to drive slushy and he's gunna make it shift quicker and all that so i'm really pumped to get it back (which'll be around tuesday).
Old 08-21-2009, 08:09 PM
j cAT j cAT is offline
Re: Some bad news.
you should get a NEW torque converter ....the old one will screw up the rebuild in a short time...also flushing of the radiator/tranny lines is needed..
Old 08-21-2009, 10:18 PM
bhw33191's Avatar
Re: Some bad news.
Well this shop specializes in transmissions only so i'm sure they know what they're doing.
