Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 04-04-2003, 03:21 PM
crj_lll crj_lll is offline
Send a message via AIM to crj_lll Send a message via MSN to crj_lll
Question H22A Transmission Final Drive
Does anyone know of a final drive upgrade for those of us with an H22A egine and applicable transmission? I am definatly NOT talking about the SH prelude.:flash:
Old 04-08-2003, 09:42 AM
D2daT2daM D2daT2daM is offline
the japanese accord euro r came with different 4th+5th gear syncros and final drive, I read in sport compact car that that tranny from the accord euro r is a must have for h22 owners
Old 04-08-2003, 11:13 AM
Accord Euro R
What year is that euro r and does it both right up?
Old 04-08-2003, 07:30 PM
Re: Accord Euro R
If you have a h22a it should bolt right on it bolts onto h22a vtec engines, www.inlinefour.com check it out
Old 04-08-2003, 10:31 PM
This is a oline store. Where is the info on the accord euro bolt on tranny.
Old 04-09-2003, 07:56 AM
Re: ????
they sell the euro r tranny and tranmssion together if you looked , 2001 model they are selling but maybe if you send them an email they wil tell you where to get the euro r tranny or you can find it on ebay
Old 04-09-2003, 03:41 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
also...
the SH and base have the same trans and final drive.
the difference is in the ATTS system. which has nothing to do with the gearing.
Old 04-09-2003, 06:40 PM
Here we go again
We are not tallking about the SH or the ATTS. Your comment was usless. You just had to stick your 2 cents in, I see:smoka:
Old 04-09-2003, 07:26 PM
srelick srelick is offline
Send a message via AIM to srelick Send a message via Yahoo to srelick
H22a Tranny
The final drive ratio depends on which car the tranny came from.
Which tranny are you refering to?
Prelude VTEC USDM/JDM/EDM/ADM
Accord Euro R
There are three different final drive ratios
one must first finish in order to finish first.
Old 04-09-2003, 07:30 PM
People people people
Please remember the original question. Final drive upgrade for an h22?
Old 04-10-2003, 10:10 AM
Upgrade
I need to know which tranny you're starting with in order to be able to give you the available choices.
Old 04-10-2003, 10:12 AM
Tranny
I am just talking about the normal transmission for a 1992 Honda Prelude SI. Non-Hydro
Old 04-10-2003, 10:17 AM
tranny
Are you planing on using a turbo or nitrous setup?
If, so get a Prelude S (base model) tranny or final drive gears.
If, not ( All Motor ) get the final drive from a H22a (USDM Prelude or Euro R Accord).
Old 04-10-2003, 10:20 AM
Final Drive
I have not decided where I am going but I know I am not going to use a final drive made by honda, unless the current Euro R / TSX final drive would work. I found a 4.7xxx final drive. All the SI's atround the world had, at best, a 4.266 and the s you recomend for a turbo is less than that. I was looking for other options like the 4.7xxx.
Old 04-10-2003, 11:30 AM
Tranny
What is your intended purpose for the car?
Do you understand gearing?
The higher the number, the taller the gear, the shorter the gear is.
The lower the number, the shorter the gear, the longer the gear.
If drag racing is the intended purpose than you need only to concern your self with 1st through 4th. If it's for road racing, you have to redo all the gears as well as the final drive ratio.
Fifth gear is for highway use, like an overdrive. In the case of the different tranny's, my prelude s tranny was just going into fourth at the end of the 1/4 mile, now it's in the middle at the end. A prelude vtec tranny would be well into fourth at the end. The "S"'s fourth is almost the same as the "Vtec"'s fifth gear ratio. The final ratio makes a big difference also.
Head to head, I shift like this;
S; 1st 2nd 3rd 4th 5th
Vtec; 1st 2nd 3rd 4th 5th
That was before the turbo. Now I shift before the Vtec only because of the increased power.
Shorter gearing keeps you in the power band longer and requires less shifting which losses less time. But there are a lot of variables.
The car has to be geared for it's real intended purpose. Mine is geared for road racing.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
