Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-20-2009, 04:50 AM
eagleesi1953 eagleesi1953 is offline
Engine burning oil
1997 Eagle Talon 2.0 ESI has 109,000 miles and is burning a little oil. Should I change to a different weight oil or synthetic,which one is the best?
Old 08-20-2009, 06:11 AM
MoW MoW is offline
Re: Engine burning oil
every engine burns a little oil, some of it gets inside the cylinder where it gets burned. just top it up.
www.ministryofwheels.com
Range Rover III 4.4
Old 10-06-2009, 04:04 PM
PlyLaser93's Avatar
PlyLaser93 PlyLaser93 is offline
I use a product called "smoke away". you can get it at advance auto. It works great, it even helps lubricate the motor on start ups, since the oil drains back into the pan over night. It last for about 2,000 miles then starts to burn a little again. I just watch the level for the next 1,000 miles. then change it. then start the process all over again.
Old 10-06-2009, 06:20 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Yea as long as it still runs good just keep topping it off. You can try smoke away, it might help some. Depending on where you live you may could run a little thicker oil, it the summer it shouldn't be a problem but it may get to cold for it in the winter.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
