Old 08-20-2009, 01:48 AM
vr4choke's Avatar
vr4choke vr4choke is offline
Send a message via AIM to vr4choke Send a message via MSN to vr4choke
disaster in paradise
i have a huge problem. i was cruisinon the highway today and when i passed someone all was well. however, upon competion of the passing i let off the throttle and instead of hearing BOV i heard this weird snapping sound like a hose blowing off. i pulled over and popped the hood to check all my hoses ( i was thinking i must not have bolted something down tight enough when i did the BOV install ) but everything looked normal. i continued to drive and didnt notice anything strange. then. . . on my way home after work i started noticing some major issues that only occure under 'boost' conditions. i say 'boost' cuz it wont actually boost. it'll hit around 1 psi then start jerking. it will go no higher. i can rev all the way to redline as long as there's a vaccuum, but if i hit it hard, it freaks out. instead of spool i'm hearing this weird wooshing sound and it absolutely WILL NOT go over like 2 psi. and it runs terrible under any boost. am i experience compressor surge as a possible result of a faulty, newly-installed BOV? either way, i'm currently rolling a vr4 that cant boost. this must be how a castrated man feels. . .
Old 08-20-2009, 08:55 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: disaster in paradise
Sounds like an IC pipe popped off. Your absolutely sure they are all on there all the way?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-20-2009, 09:16 AM
Girly VR-4 Girly VR-4 is offline
the clamp for the y-pipe probably snapped, and you're now losing air out the y-pipe. Check all of your clamps and check the IC piping. something popped off.
www.groundzeroperformance.com
www.3swarehouse.com
1991 Stealth R/T Twin Turbo... sitting...
1996 Orchid Pearl Stealth R/T.... daily driver duty, 275k+ miles and counting!
1995 3000GT Spyder SL... being modified...
Old 08-20-2009, 12:24 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Yeah you are definately leaking a lot of air somewhere in your IC piping. If I have my guess I would go with what girly-VR4 just said as Y pipes are notortious for that and the fact that you just had all that IC piping pulled apart and probably didn't tighten one down tight enough.
Also, what did you plug the hole in your Y-pipe with when you put on the BOV? Did you check that hole after this happend?
Old 08-21-2009, 12:42 AM
vr4choke's Avatar
i didnt plug anythng man, its recirc.
anyways it turn out i'm half retarded . the pipe going from the y-pipe to the passenger side intercooler was loose. it wasnt all the way off, i guess it was just loose enough to leak. so i have secured it and all is well. i was all freaked out about nothing.
