Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 08-19-2009, 12:24 PM
ssprauve23 ssprauve23 is offline
Exclamation 99 explorer ac problem
as of last week my ac stopped blowing cool air. so i thought it just needed a recharge. after checking the gauge there was already the proper amount of freon in the vehicle. However, the compressor is spinning very slow and squeaking. how can i fix this?
Old 08-20-2009, 03:53 PM
Davescort97 Davescort97 is offline
Escort guy
Re: 99 explorer ac problem
The clutch on the AC compressor is slipping. The cause could be the clutch itself or a bad relay or wiring connection. Apply 12 volts to the compressor wires and see if the clutch works OK. If so you have a bad relay or wiring. If the clutch slips and squeaks as before with 12 volts to the compressor the problem is most likely the clutch itself or a bad compressor.
Old 08-21-2009, 12:52 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
You may also want to check the clearance of the clutch to make sure it isn't loose and the gap growing. If that's the case, you'll want to get it fixed before it flies apart and the belt comes off.
Are you sure it's the A/C clutch that's making noise and not the idler/self tensioner pulley that's not properly tensioning the belt, allowing it to slip on the A/C compressor pulley?
-Rod
