Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 08-19-2009, 11:14 AM
laxman21's Avatar
laxman21 laxman21 is offline
Misfiring or stumbling under light load
99 burb. 175k.
Started to stumble at highway speed with light gas pedal. Runs fine when under heavier load.
plugs, wire, cap rotor all about a year old. This fixed it when it was doing it before.
Mechanic thinks it the spider injector because he gets some black smoke out of the pipe when accelerating. Leaking extra fuel into cylinder.
Any other suggestions or should I just replace the injector with the updated one?
Edit: no codes or SES light
Should I opt for the cleaning before replacing route?
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 08-19-2009, 11:59 AM
j cAT j cAT is offline
Re: Misfiring or stumbling under light load
Originally Posted by laxman21 View Post
99 burb. 175k.
check distributor ,,,when bearing goes bad rotor wobbles..
if if starts and runs good at idle the fuel should not be a problem..
black smoke on throttle increase usually ignition ...poor spark,,,at the incorrect time...
Old 08-19-2009, 12:29 PM
laxman21's Avatar
Will check.
Remove cap and check to see if there is play?
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 08-20-2009, 06:17 AM
Jeremy-WI Jeremy-WI is offline
Have the mechanic hook it up to a scanner and check cam retard, it should be 0 degrees +/- 2 degrees. If it is -5 or more negative, pull the distributor and check the gear, it could need replacement
Old 08-23-2009, 01:00 PM
laxman21's Avatar
So how doies the wobble look
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 08-23-2009, 09:34 PM
hard to tell.....try to get a look at a new one to compare,,,,or go to a scrap yard to check a few..it looks like it does move alot..
how does the cap /rotor contacts look...is the metal distorted where the rotor rides..
777stickman 777stickman is offline
The service manual says there should be no noticeable rotation in the rotor. It looks like you may have enough rotational play to cause your trouble.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 08-26-2009, 02:22 PM
ken_man_1 ken_man_1 is offline
I just went through this distributor stuff on a 99 gmc 5.7, and that is what my new gear looked like. The left to right movement should also move up and down as well. The gear is spiral - thus the up/down and left to right movement. They have a little play - and from what I can see on the movie you posted, mine looks the same.
Another little thing to check (since you have the cap off)... Take a wrench and put it on the crank bolt. Move it slowly back and forth and watch the distributor. If it moves pretty fluidly, then more than likely your dist gear is okay. That means that your timing chain is pretty good still, as well. But if it is jerky, then you need to investigate the reason for jerking.
I had to pull the distributor in mine cause the gear was so worn, that 3 teeth were missing. It ran like crap for months on end (this is a plow truck only) until they put me on the job to fix it. It was only under heavy load that it failed tho. Light load was no problem.
I've read somewhere that the fuel pressure regulators like to leak on these trucks. Unfortunately in order to find that out, you need to pull the plenum. However, it's usually easy to spot because underneath the mount for the regulator, it's nice and clean. It it's not leaking, it will normally be pretty dark or black even.
Hope this helps m8!
