Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 08-18-2009, 07:48 PM
oldkckr41's Avatar
oldkckr41 oldkckr41 is offline
Instrument cluster 2004 Tahoe
Does anybody know what goes out on the instrument cluster.And if so can it be fixed. I know there is a recall but I have to many miles. Mine has the speedometer and oil pressure gauge pegged.
Old 08-19-2009, 11:45 PM
roadrunner2 roadrunner2 is offline
Re: Instrument cluster 2004 Tahoe
The instrument cluster can be removed, but first you must disable the airbag system.
Remove the cluster bezel.
Lower the steering column as low as it will go.
Remove four retaining screws (at each corner) .
Pull the cluster forward enough to disengage the single, large electrical connector at the back, then pull the cluster out, tilting the bottom out first.
My problem is not knowing if the individual gauges can be replaced or if the complete cluster has to be replaced.
The problem with doing nothing is not knowing when you're finished.
Old 08-20-2009, 07:24 PM
wafrederick wafrederick is offline
Banned
You can have the dealer send the cluster in to get fixed and it also has to be programed with the Tech 2 when it is done
