2003 lincoln ls throttle codes
The other day I was driving and the car shut off on me. Turned back on and will go into drive but wont allow me to give it throttle.
The codes that show up are : P2104 Throttle actuator control system-Forced Idle P0223 Throttle/pedal position sensor-B circuit high voltage P2111 Throttle actuator control system-stuck open P2135 Throttle/pedal position sensor-A/B circuit correlation I have to mention that this occured about an hr after I had it detailed and the engine was also washed. I'm new to this but before I went out and spent a lot of money I wasnted to get some feedback. I have the 2003 Lincoln Ls 3.0 premium. I've also had transmission slippage for the past 15000 miles but only occurs after i've been driving for about 15 mins. It shifts smoothly every morning for the first 15 mins or so. |
Re: 2003 lincoln ls throttle codes
Try this first for it doesn't cost money, then see if it reoccurs. The 2003 has an extended warranty for 100K or 10 years that cover the coils. |
Thanks a lot for the reply. In fact water had gotten in the wells. The mechanic replaced all the spark plugs and took the car out of limp mode. I picked the car up today and seems to working great. I hope that was all that was wrong b/c he charged me $240 and all he did was change the spark plugs.
$240 to change the spark plugs, if he did all 6 of them, is not bad for the V6.
-Rod |
