Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-18-2009, 04:48 PM
violent31601's Avatar
violent31601 violent31601 is offline
Send a message via AIM to violent31601
blinker relay 99' GS-T?
where is this located, my turbo timer for a while now has been resetting itself every other time I use my blinker and figured changing the blinker relay could maybe fix this problem.
Old 08-18-2009, 10:09 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: blinker relay 99' GS-T?
It's inside the dash. I believe if you pull out the enter vents where the rear wiper switch and defroster are located, turn on the flashers and you'll hear and see the relay. I believe it's mounted on a bracket closer to the passenger side IIRC.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-20-2009, 08:26 AM
thanks for being the only one to ever reply to my threads anymore
I found it, I saw somewhere point out it was in that area but I wasn't sure, but I turned all the sound off and listened for it.
thanks again.
Old 08-20-2009, 12:19 PM
david-b's Avatar
Dave is THAT guy
No problem. I try to help where I can.
75 Monte Carlo
Old 08-20-2009, 12:22 PM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
are you speaking of the little black box?
if so, i tried finding that booger one time...took me several attempts lol
found it hiding behind the top center vent like he said...
*by the way, if you NEED a blinker relay, ill sell you one for cheap, i went to the junkyard to find one and got 2...)
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
