Old 08-17-2009, 09:45 PM
rcam rcam is offline
blower motor
1998 olds intrigue, v6, blower motor is noisy, also lost lowest speed. Is it difficult to replace? VIN 1G3WH52K3WF339033. RCAM
Old 08-18-2009, 09:43 AM
carbon02 carbon02 is offline
Re: blower motor
The squealing is probably the motor itself. The loss of a speed is probably the blower resistor which is located near the motor assembly.
While the top of the blower can be seen by removal of the black plastic above the windshield on the passenger side, the removal of the blower is done from inside the car. Never done this repair before, but I found the following site that's pretty close to the procedure on the Intrigue, and should help you.
As this link mentions some people have actually had luck lubricating the motor, but how long it lasts, vs. getting up under the dash is the key question.
All credit for the link below goes to the author of the link.
http://redhouseon7th.com/redhouse/ho...ent/index.html
2002 Oldsmobile Intrigue, 3.5L, GX --121,000 Miles as of 2/4/2011
2000 Oldsmobile Intrigue, 3.5L, GX --81,000 Miles sitting in garage awaiting shift kit P1811, and potential water crossover gasket repair.
Old 08-18-2009, 07:31 PM
99intriguePA 99intriguePA is offline
Re: blower motor
You received good advice from carbon02. I removed the noisy heater motor from my '99' around 5 years ago - pulled it apart and greased the bushings - still running fine.
As for the low speed loss its probably the resistor. Its up under the dash on the firewall - a little tight but not impossible to change. I believe I got mine from Advance auto - had to order as they didn't have it in stock.
