Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-16-2009, 09:09 PM
Dec1201 Dec1201 is offline
Source for PCM wire harness connectors
I'm adding some after-market equipment to a 2007 police interceptor that requires cutting and tapping some wires going to the Power Control Module. I would rather not cut wires on the factory PCM wire harness.
I thought I would buy or build a wire harness extension. Does anyone have a suggestion on a source for the 70 pin PCM connectors? I've looked online and haven't been able to come up with anything.
The part number on the PCM connector is 5L3T-14A464-DA-041
Thanks.
Old 08-17-2009, 06:25 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Source for PCM wire harness connectors
Instead of cutting the wires, just strip the coating back so the wires can make good contact. That way the original wiring maintains its integrity and if you remove the add-ons, the wiring will not be harmed.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
