Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 08-16-2009, 07:24 PM
mcoe0397 mcoe0397 is offline
Angry need help on 7mge swap-no start
I have a 91 toyota cressida and blowed the head gasket so I swaped the 7mge engine with a 7mge out of an 87 supra the swap went smoothly until I discovered the wiring issues and that the distributor was different...does any one know if this distributor will work??? and if so why wont my cressida start??? The timing is right I have spark and I have fuel...it will fire if I spray starting fluid in the throttle but wont stay running...please help before I send this cressida/supra to the toyota graveyard.
Old 09-11-2009, 03:11 PM
ese951's Avatar
ese951 ese951 is offline
Re: need help on 7mge swap-no start
check if your getting power to your injectors.... if you are, keep the switch on and lean into your engine and try to listen for your injectors spraying
