Old 08-16-2009, 12:00 PM
lilwopaho lilwopaho is offline
Fans
I have a 1995 windstar(3.8). When it is running the temp gauge will get to hot before the fans kick on. Could this be the CCRM (constant control relay module)?When the temp gauge reads above 1/2 way the fans will not kick on also. 195 degree stat in it.
Old 08-16-2009, 08:12 PM
wiswind wiswind is offline
Re: Fans
There are 2 fan speeds.....LOW and HIGH.
AT a given temperature, the PCM sends a signal to the CCRM to energize 1 relay to turn the LOW speed fans ON, using a dropping resistor to lower the voltage applied to keep the fans at LOW speed.
It is VERY COMMON for the radiator fan DROPPING RESISTOR to fail.
If the coolant temperature continues to rise, the PCM sends a signal to the CCRM to energize 2 different relays (due to more current) to turn the radiator fans ON at HIGH speed with FULL voltage applied.
Here is a picture of the radiator fan dropping resistor, located on the top of the metal front bumper, below the passenger side headlight.
As you can see.....it is visible when looking down as in the picture.
http://rides.webshots.com/photo/2087...11220610aPcAin
To test to see if the low speed radiator fan operation is OK, with the motor running at idle.....turn the A/C ON, the radiator fans should come ON and STAY ON.
If they don't, first thing to check is the dropping resistor.
I have had the CCRM fail.......but the dropping resistor is more likely......and is cheaper.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 08-17-2009, 02:39 PM
Re: Fans
Thanks for the help. its broke. i will replace it after work on tuesday when the part comes in...............also having problems with my 94 SHO taurus. gets gas and spark. but wont stay running. stalls at idle or when driving.
Old 08-17-2009, 02:46 PM
Re: Fans
Thanks for the help. its broke. i will replace it after work on tuesday when the part comes in...............also having problems with my 94 SHO taurus. gets gas and spark. but wont stay running. stalls at idle or when driving. i should have kept my Comet.lol.............. its pretty hard that both cars are down and i have 4 kids.
Old 08-17-2009, 07:40 PM
Re: Fans
I am not up on the '94 SHO, but if it has a Idle Air Control (IAC), you might check that.
Common symptom of IAC sticking is stalling when your foot is not on the accellerator.
Try cleaning it first with WD-40 or SeaFoam Deep Creep (spray version of SeaFoam).
Otherwise, before spending money on the exotic......make sure that you are up to date on the routine maintenance items......and some Berryman's B-12 Chemtool fuel system cleaner in the gas tank to clean the injectors out.
1996 3.8L Windstar
