Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 08-16-2009, 12:50 AM
BIGPROFITT BIGPROFITT is offline
Send a message via Yahoo to BIGPROFITT
Vibration
I have a 2002 Pontiac Montana with a 3.4 liter engine. While driving the engine runs very smooth (or appears too). While at a stop in drive at idle there is a terrible vibration. Sounds and feels like the van is going to come appart. Engine does not visually appear to be shaking or vibrating. Kind of sounds like a motor mount may be bad but can't verify that. Any ideas?
I would greatly appreciate any help.
Thanks
Russell
Old 08-16-2009, 12:02 PM
shawcross shawcross is offline
Re: Vibration
that could be the problem or the spark could be rough
Old 08-16-2009, 12:15 PM
Re: Vibration
I thought it could be the spark plugs so I replaced them and the wires.
Any other suggestions?
Thanks
Old 08-16-2009, 09:28 PM
roadrunner2 roadrunner2 is offline
Re: Vibration
Has the throttle body been cleaned or the IAC valve checked?
You can check the motor mounts with a pry bar, while there check the tranny mounts too.
The problem with doing nothing is not knowing when you're finished.
Old 08-16-2009, 09:29 PM
Re: Vibration
How would you recommend I clean the throttle body?
I did clean the IAC, but have not replaced it. Would you recommend replacing the IAC?
Thanks
Russell
Old 08-22-2009, 09:15 PM
mhall02 mhall02 is offline
Re: Vibration
I have a bad vibration at idle as well in my '99. I thought it may have been plugs or wires but turned out to be a sagging motor mount (so I was told). I'm just ignoring it for now, everything else seems fine and now at 192,000 miles, I'm not sure how much longer I will have it.
1999 Pontiac Montana
202,000 miles and still going
Old 11-30-2009, 12:33 PM
scooter72908 scooter72908 is offline
Re: Vibration
I was wondering if anyone as solved the vibration issue. I have a 99 Montana and I'm experiencing the same vibration problem. I have replaced my plugs and plug wires, however I've not checked the motor mounts. I did notice this morning that the vibration would increase when the front blower was on High speed and would decrease in vibration when the blower was turned down to a lower speed.
