Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-15-2009, 06:25 PM
2dooreighty5 2dooreighty5 is offline
New headers not fitting
I just got new headers and I have remooved the old ones and I remooved the starter and some other things that were blocking me from putting the new ones in.... But the steering colum is still in the way and on the passenger side it's rubbing on the bottom end like on a control arm or the frame.....I'm wondering if any one has done this or if I have to shave or modify the car.... Didn't think I would have to do that
Old 08-15-2009, 10:41 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: New headers not fitting
Not really enough info here. What are they going on (I assume a 2-dr '85 Caprice)? What are they designed for? B-body headers designed to fit 1977 or later should work fine. I can see you running into trouble if you got headers for A/G-body (Malibu, Monte Carlo, El Camino).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-15-2009, 11:42 PM
yea it's a 305 and the headers are meant for 79 to 87 full size chevy... I can probably get the right side to work by remooving the steering colum but the left side looks like it need to be custom.... I didn't think I would have to do that.... Any one run into this problem
Old 08-16-2009, 10:37 AM
96capricemgr 96capricemgr is offline
Have you tried putting either of them in from the bottom?
96 Caprice Medium Garnet Red
11.56 at 115.9mph naturally aspirated
94 Caprice wagon, rotted out POS
Old 08-16-2009, 09:28 PM
rhandwor rhandwor is offline
Match the gaskets to the block if they fit match the headers to the gasket.
Old 08-17-2009, 06:53 PM
That might help if he said they would not bolt up.
