Go Back   Automotive Forums Car Chat > Auto Collision Network
Auto Collision Network The forum for Automotive and Collision repair schools, instructors, teachers and individuals in the industry helping to produced better qualified employees. In association with A.D.Smith NACAT, CRIN, ASA.
Old 08-15-2009, 10:10 AM
rodgerda rodgerda is offline
Question water based metalic silver! can i wet sand to smooth finish before clear?
hi guys im new and my name is dave! i have refinished my bonnet, using metalic siver water based paint problem is i want to flatten it to give another coat of paint due to dirt on the surface! is this possible and can i wet sand using water once cured! 2k was much easier lol thanks in advance
Old 08-23-2009, 06:46 PM
LearnAutoBody's Avatar
LearnAutoBody LearnAutoBody is offline
Auto Body Mod
Re: water based metalic silver! can i wet sand to smooth finish before clear?
I have not used enough water borne yet to give any advice. Anyone else have any suggestions?
DIY Auto Body Tutorials
"Coming together is a beginning; keeping together is progress; working together is success."
`Henry Ford
Old 08-27-2009, 09:10 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Ive never used it either, but i've heard once cured you can water sand like any other paint.
Old 08-27-2009, 07:14 PM
Pac-Man_G Pac-Man_G is offline
Send a message via AIM to Pac-Man_G
No.water based paint,should not be water sanded. may i ask what kind of water base paint line you are using.also did you use a waterbase dryer?
Old 11-04-2009, 12:09 PM
chaswe75 chaswe75 is offline
That is not necessarily true. Waterborne base coats can be wet sanded in between clearcoating. Of course you have to careful not to saturate the panel in water, but lightly wet your 1000-grit or whatever you choose to use. You need to thoroughly dry the panel before doing so. I've done it, I've sprayed it, and PPG trainers for classes also have agreed it is acceptable. Personal opinion is one thing, the truth is another.
Old 11-05-2009, 11:19 AM
PPG Envirobase. Yes I use stand-mounted venturis. There are varying opinions on this. It is also possible to use the solvent-based(not water-based) wax/grease remover as a lubricant. Let me say that this is possible with PPG. I can't elaborate on other manufacturer's waterborne base material. I should not have said waterborne base in general. What product do you use Pac man?
