Old 08-15-2009, 05:26 AM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Some paint questions
I'm in the middle of building a 1/24 Monogram Lamborghini Countach. I've finally gotten up to painting the interior and I was wondering a few things. Should I use gloss black or flat black for the leather dashboard, and what color should I use for the tan leather interior?
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 08-15-2009, 05:31 AM
jrlugo45 jrlugo45 is offline
Re: Some paint questions
if you do not have any semi-gloss black, i would go with the flat black, in my opinion i have noticed gloss colors in the interior seem to look very unrealistic. sorry if im no help.
Old 08-15-2009, 05:40 AM
Dyno247365's Avatar
That makes sense. Thanks for the speedy answer.
Old 08-15-2009, 06:15 AM
lotus123's Avatar
lotus123 lotus123 is offline
I've heard that painting flat black, then rubbing your finger on your scalp or side of nose and wiping onto the paint, gives a unique leather-like sheen!
Ken Hartlen's site also gives good advice:
http://pages.interlog.com/~khartlen/tips/seats.htm
Old 08-15-2009, 09:35 AM
Didymus Didymus is offline
Most leather has a slight sheen. For me, most flats are too flat and dull. On the other hand, I think even a semi-gloss finish is too glossy for car interiors.
If you can mix paint, start with a flat version of the color you want. Then mix in just a small amount of the glossy version of the same paint. To my eye, that produces a realistic leather look.
Also: If you're brushing water-based acrylics like Tamiya or Polly Scale, try mixing in a little Tamiya X-20A thinner instead of water or alcohol. Brushing will be easier and the finished interior will look smoother and less like brushed paint.
Ddms
Old 08-15-2009, 10:13 AM
Dyno247365's Avatar
I'm using Testors enamel paints.
I found a bunch of old flat tan/tan paints so I'm gonna to see how they come out, maybe mix them, same with flat black/gloss back.
Old 08-15-2009, 10:17 AM
rodgerda rodgerda is offline
anyone help with water based painting?
Old 08-15-2009, 12:44 PM
Dyno247365's Avatar
One last question. I just bought a cream color, only to find out it looks perfect but it's glossy (without saying glossy or flat). should I just go ahead with mixing flat tan and flat white or is there something I can do to take some shine out?
Old 08-15-2009, 01:40 PM
Yep.
Anything else?
Ddms
Old 08-15-2009, 02:45 PM
to get the shine out you could get some matte clear coat, u can get a cheap can at your local walmart.
my name is Robert and im back after not building for 3+ years. hopefully some W.I.P pics coming soon.
Old 08-16-2009, 09:55 AM
Dyno247365's Avatar
Okay so I screwed up the interior, which has like 20 coats of paint on it, from fixing spill after spill, and on top of that it's the wrong color, and I was getting too frustrated about it.
Is there anything I can do to remove all of it or should I look for a new model?
I was looking up remedies and one guy said to soak it in brake fluid. Ever tried that?
Old 08-16-2009, 10:43 AM
Dyno247365's Avatar
I also read about spraying the enamel with oven cleaner and sealing it open, so the fumes eat up the enamel or something like that. Do it outside of course.
Old 08-16-2009, 11:52 AM
stevenoble's Avatar
If it's enamel I'd go with the oven cleaner. Put the parts you want to strip into a plastic bag and spray in a decent quantity of oven cleaner (enough to cover the parts) Seal the bag and leave overnight. The paint will scrub of the following morning with ease, use an old tootbrush under a running tap for best results. I wouldn't recommend brake fluid. It will do the job but in my experience it leaves the plastic very brittle and because of this I won't use it.
Steve Noble
Old 08-16-2009, 12:29 PM
Dyno247365's Avatar
There's a lot of paint so I don't think the brake fluid will really damage the plastic and I read it works in much less time. A handful of hours maybe.
Old 08-16-2009, 01:24 PM
stevenoble's Avatar
Well it depends how quick you want to strip it I suppose. I'd rather have it stripped clean and no brittle plastic, even if it takes a little longer. Doesn't matter how much paint is on it, it won't protect the plastic because the brake fluid is stripping the paint off, so the plastic will be exposed to the brake fluid anyway........
Steve Noble
