anyone can help, what is problem on my car toyota gli'98 i can see smoky muffler after a long drive 50km, when i start to slow down at toll gate and run again i see a bluest smoke and i feel my car i slow to accelerate.
thx, vgnoB_31 |
Re: gli'98 smoke after
Its probably a gasket problem or rings.
Increase in blue smoke on deceleration is a sign that oil is getting sucked by the valve stem seals.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. Last edited by jdmccright; 10-22-2009 at 09:03 AM. Reason: brain fart |
Yeah if you do a cylinder leakage test you would know if its leaking out of intake valve or outake valve ( valves are not seating right).
A leak down test can show if oil can get by the piston rings (hissing through the crankcase vent), but won't show if oil is getting by the valve stem seals due to burned valves as you suggest. You are confused with having a lack of compression in a cylinder. Please be mindful of the symptoms the originator has described.
However, if you are addressing the lack of acceleration then a compression and leak-down test would be in order.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. Last edited by jdmccright; 10-21-2009 at 12:46 PM. Reason: Added info |
jdmccright is correct.
Blue smoke while accelerating: worn rings Blue smoke while decelerating: worn valve seals (or guides) |
