Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 08-14-2009, 05:28 PM
martel21 martel21 is offline
i hope someone can help me
i have a 04 impala ss an my dash light, air control light dont come on i check for fues there all good is there something burned out. if so where can i find it an replace it thank
Old 08-14-2009, 06:36 PM
maxwedge maxwedge is offline
A990 racer
Re: i hope someone can help me
Air control lite? Be more accurate/specific.
Old 08-16-2009, 10:29 AM
my dash lights dont work the ones that light up ur window buttons, ur dash, radio nobs an i chk all fues an there good someone said the headlight switch but i dont know how that would be thats for ur headlights
Old 08-16-2009, 10:38 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
The same thing happened on my 2000 Impala LS and it was the headlight switch ! The switch contains the electronic circuitry that controls dimming the lighting (as you mentioned ) when the DRL's turn off and the regular headlights come on . With mine , when the regular headlights came on , I would lose all the lighting in the dash cluster , the door power lock and window buttons , and floor mounted gear shift indicator . Replacing the switch cleared up all the problems . Good luck !
" Sometimes I grow so tired "
Old 08-16-2009, 10:44 AM
Thumbs up Re: i hope someone can help me
thanks man ur a life saver iv been going back an foward on forums trying to find out no one would help. i would like to ask another ? if u dont mind
Old 08-16-2009, 10:48 AM
oldblu65's Avatar
Glad to help , if I can ?
my canister behind the side panle leaks gas an when i try to put gas in it, it run out the canister so i have to drive it for like 15min an then fill it up does that mean i have a bad valve in the canister or a bad canister
Old 08-16-2009, 10:50 AM
oldblu65's Avatar
What canister ( behind the side panel ) are you referring to ? I'm not sure I'm following your question ? You say " put gas in it " , are you talking about the gas filler door on the side of the car ?
Old 08-16-2009, 10:55 AM
the charcoal canister its on the left side by where u feel up ur tank
Old 08-16-2009, 10:58 AM
oldblu65's Avatar
When you say charcoal canister , are you talking about under the hood ? I'm confused about what you're referring to ?
Old 08-16-2009, 11:09 AM
its the evac canister ya some ur under the hood but mine is by the gas tank fill up if u were to look under the car behind the left back tire that were mine is
Old 08-16-2009, 11:10 AM
it gets rid of most of the gas vapors
Old 08-16-2009, 11:15 AM
oldblu65's Avatar
I'll be honest , I don't know the answer to that particular question but believe if you read my PM to you and go to the suggested sites , you can get an answer there .
Old 08-16-2009, 11:19 AM
thank my friend u been very helpful
Old 08-16-2009, 11:34 AM
oldblu65's Avatar
You are welcome , glad to help !
